having problem with storing data in array
How do i increment an array ? If i wan to start reading from the 2nd data.
Message 11 of 18
(2,821 Views)
Index Array gives you a single element from the index you specify Perhaps you might want Array Subset if you want the entire rest of the array starting at the index you specify. I recommend browsing around the array palette with Context Help turned on. Hover over each function in turn. You may be surprised at what you can learn.Smiley Wink
Message 12 of 18
(2,819 Views)
I can't store my data into the array. It keep overwrite at the same location. Below is the attached vi.
Message 13 of 18
(2,803 Views)
Hi ander99,
small tip: shiftregisters are your friends, the wire is the variable.
What do you try to do? Can you explain please? You should upload your example with values in your arrays. Insert your values and make them default.
Mike
Message 14 of 18
(2,801 Views)
Sorry i forget about the value. I did with shift registers. Maybe i do not know the correct way. Thank for your help mike.
Message 15 of 18
(2,792 Views)
Accepted by topic author ander99
Hi ander99,
can you please explain which array you mean? I changed a bit in your vi and added a build array component, maybe it was the correct place for it.
Hope it helps.
Mike
Message 16 of 18
(2,784 Views)
Hi Mike,
Sorry is the Loss (401) i want as output. Because it keep overwrite at the 1st index. Hmm..sorry i can't open that file. I'm using Labview 7.1. Thank for your time.
Message 17 of 18
(2,777 Views)
Adnan's post in reply 5 gave the answer.   How come you didn't implement that?
Here is a screenshot of Mike's code as LV 7.1 is too far to say back to without extra effort and a PC with LV 8.0 installed on it.  The code is duplicated just to show the other case of the case structure without broken wires.
Advantages:  no local variables, no stacked sequences
Message Edited by Ravens Fan on 02-26-2009 09:05 AM
Message 18 of 18
(2,770 Views)
