hdl node parameters
I am a beginner in VHDL, but...... is there a bug here in LabVIEW?
In the configuration Window of a HDL node, I have selected the following parameters:
Name: X,  direction: in, type: bool, length: -
Name: Y,  direction: in, type: bool[], length: 0;
Name: Z,  direction: out, type: bool length: 0;
LabVIEW then generates:
entity hdlnode  is
   generic(
      ClockFrequency : Integer := 40000000;
      InSingleCycle : boolean := false
   port(
            clk : in std_logic;
            reset : in std_logic;
            enable_in : in std_logic;
            enable_out : out std_logic;
            enable_clr : in std_logic;
            X : in std_logic_vector(0 downto 0);
            Y : in std_logic_vector(1 downto 0);
            Z : out std_logic_vector(0 downto 0)
end hdlnode;
I am confused why LabVIEW has implemented X and Z as  vectors. This does not seem correct, because:
Name: X, direction: in, type: bool[], length: 1
and:
Name: X, direction: in, type: bool, length -
both generate exactly the same VHDL code.
Why does LabVIEW behave in this way?
I was expecting, LabVIEW to generate something like:
X : in std_logic;
Z : out std_logic;
Mark
Message Edited by sparkymark567 on 11-02-2009 05:35 AM
(4,589 Views)
Hello Mark,
Does the compiled code work?
(4,551 Views)
I am suggesting that there is a bug in the way that LabVIEW generates VHDL code from the configure HDL node dialog.
Type Boolean causes LabVIEW  to generate code for a VHDL vector of length 1 (i.e. an array) and in my view it should not be a vector. If on the other hand there is some reason why LabVIEW can only use vectors, the option for a Boolean should not be in the dialog.
But as I am a beginner in VHDL, I can not say for certain whether it is a bug.
Does the code generation also seem incorrect to you? explanation? or please raise a CAR number so the bug will get fixed.
Mark W
Message Edited by sparkymark567 on 11-09-2009 07:11 AM
Message Edited by sparkymark567 on 11-09-2009 07:12 AM
(4,542 Views)
Accepted by topic author sparkymark567
Is a CAR generated?
(4,505 Views)
This was reported to R&D (ID:196209) for further investigation.
The reason I ask if it compiles and works ok, is because as far as I can see
and
X : in std_logic;
are similar things.
(4,498 Views)
You can wire a boolean into the HDL Node with VHDL vector of length 1, yes.
...but the dialog forces you to use a vector in VHDL (or create a new variable and copy the value in). Either way works fine, but you  have to write more VHDL code, than would otherwise be necessary.
Mark W
(4,486 Views)
