head mounted display
I have an idea to implement head mounted display in LabVIEW.I saw some videos and have an idea to implement it in labVIEW.Is it possible to do it.
(3,609 Views)
Yes.
(3,583 Views)
LabVIEW is software, so you cannot mount it anywhere. However, if you have a head mounted display, you can use it to display your LabVIEW output. If the display has orientation sensors etc., you can read those into your LabVIEW code to change the display accordingly. What exactly do you have in mind?
(3,578 Views)
Based on my head movement,the camera has to rotate.But it should be a wireless connection.
(3,542 Views)
What sensors do you have to detect head movement?
(3,538 Views)
You mean like this:
Cool.
(3,521 Views)
