hearing is believing
Hello
well how can I make a sound clip using labview where a boolean variable is the control so that when the boulean is true the sound is not going to repeat it self
merci
Message 1 of 8
(4,756 Views)
Hello what I meantis that how can I play a sound clip in Labview because I do not think that there is a thing related to this option in Labview
Message 2 of 8
(4,734 Views)
Look at the functions on the Graphics & Sound>Sound>Sound Output palette.
When you pop up the function palette, see the 'Search' button? You can always use that or the LabVIEW help.
Message 3 of 8
(4,727 Views)
There most certainly is. Just open the Example Finder (Help -> Find Examples), and search for "sound". And, as Dennis pointed out, there's a whole palette with sound functions. Smiley Wink
Message 4 of 8
(4,706 Views)
hello should i use a  play sound file . vi to get a sound from a place on my computer?
Message 5 of 8
(4,657 Views)
Only if you want to play a sound like you asked.Smiley Very Happy
You could also use ActiveX for something like calling the windows media player, I suppose. That would be a bit more complicated.
Message 6 of 8
(4,649 Views)
Something like this
Tim
GHSP
Message 7 of 8
(4,647 Views)
Do the afore mentioned search of examples for "sound" then try out the "Interactive Play Sound.vi". Try things, if they don't work, or work differently than you expected you will still have learned something for future LabVIEW. If you have a road to get to your destination you usually don't learn how to get there any other way, or even if there are other ways. Searching the help/example available within LabVIEW is a good experience, sometimes you will stumble onto a method to solve a problem what was totally different than what you  envisioned.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
Message 8 of 8
(4,642 Views)
