hello I am using LabVIEW 6i and I have an error on the VI
Although there is no error on the LV error list, I still cannot run my VI since the run arrow is broken!
Can anyone explain this? thanks
LabVIEW Intermediate I level!
(2,792 Views)
There are numerous VIs missing. Some from a folder called E:\Miss Distance Source, and others from an Advanced Signal Processing addon. Assuming you actually have those VIs, I don't see other errors with the VI.
(2,788 Views)
Hello
Yes I forgot to attach those, but I do have them.
(2,783 Views)
Well, when you click on the broken arrow it should tell you what the problems are. What does it say?
(2,778 Views)
it does say anything
I restarted the program and now it is ok!
maybe it was a bug or something
thanks anyway
(2,769 Views)
