hello. I want to output the values ​​from the intensity graph.
I can't speak English, so I used Google Translate. Thank you for your understanding.
I want to output the value for the position when the mouse is clicked on the intensity graph, how should I do it?
(1,057 Views)
Hi ndtsystem,
check out this solution, change the event to "Mouse Down" or "Mouse Up" due to your requirement.
https://forums.ni.com/t5/LabVIEW/How-to-move-x-and-y-cursors-with-mouse-cursor-proportionally-in/td-...
FrankenChino
(1,022 Views)
Accepted by topic author ndtsystem
No need to jump through flaming hoops getting the index. There is a method (invoke node) for that!
Here's all you need:
(993 Views)
