hello, I would like to read the file of configuration of Max_explorer in order to obtain information on the configutation of my way SCXI 1141 (gain, value of the filter, by-pass?etc..)have you example VI. Thank
It is possible to convert textual file to read information on the various charts which constitute my measuring equipment.
(2,629 Views)
Yes, under the DAQ menu somewhere (in the Utilities sub menu I think) are VIs that allow you to read the contents of a *.daq file. You can use those functions to create a program that prints out what every you want. If you would like I could send you one that I use for reading out the data I use. Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,629 Views)
I think the VIs he is referring to are the "Get DAQ Device Info VI" and the "Get SCXI Information VI".
(2,629 Views)
