hello...interfacing of ultrasonic sensor and camera
i am making application in which ultrasonic sensor and camera is used.i am using myrio board.i have interfacing code for both ultrasonic and camera which i attached below.i need your help to build we can say logic.i want to capture the image using camera when distance measured by ulrasonic sensor is particular for example 10 inch.please help me..its very necessary for me.
(3,403 Views)
Hi sagar,
create a main VI executing (pseudo-)code like this:
WHILE
  IF distance measured by sensor == 10±x inch THEN
    capture image using camera
  ENDIF
WEND
Suggestion:
Your subVIs should not run "forever" (as "ultrasonic sensor" does at the moment) - or you need to think about data exchange between parallel running loops in different VIs…
(3,382 Views)
 hello GerdW,
                     i am in the learning phase of labview.so currently i dont know how to write psuedo code.can u please explain in detail.how to map pseudo code to original?
(3,365 Views)
Hi sagar,
you need to use suitable LabVIEW structures/functions.
- WHILE/WEND is just a WHILE loop (I guess you figured this as well)
- IF/THEN/ELSE is a CASE structure
- the rest of the pseudocode suggestion are just your two subVIs…
(3,359 Views)
hello Gerdw,
     sorry but i cant understand.whether i have to draw structure or write pseudo code?please explain with one example whole thing.thanks in advance.
(3,350 Views)
Hi sagar,
Pseudocode is a way to describe an algorithm without using a "real" programming language!
You need to code the sketched algorithm in LabVIEW!
Btw. you don't "draw" in LabVIEW, you "code"/"program"…
(3,335 Views)
