help !! Error 1047 occurred at LabVIEW: LabVIEW failed to send variable to the script server. Server
hi comunity i have  a problem with matab script of de labview , i have this problem  :
Possible reason(s):
(5,632 Views)
Accepted by topic author edwin89
We have a few documents that mention possible reason of why this error happens, could you see if either of the following apply to what you are seeing.
http://digital.ni.com/public.nsf/allkb/8BEBC0C86541224286257AF300561B5E?OpenDocument
http://digital.ni.com/public.nsf/allkb/2B3FF46C8512C4F786256CF30071BE53?OpenDocument
(5,600 Views)
hi,
now,l meet the error 1047,but l can not solve this problem, may you give me some suggestions?
thanks
(4,145 Views)
Without some specific information, the suggestions will be the same as two years ago. Have you read those documents?
(4,140 Views)
