help me for project!!
Work in a electrica company, has a "escada system", I am gliding to propose a project that uses labview, to improve the monitoreo of these systems, that equipment to use, and to pass information to me about this subject.
(2,818 Views)
Apart from not having any question in the post, I have a problem finding out what it is you want. It`s impossible for anyone to give a helpful response to a question incorporating so little information about the problem.
SCADA is a term used for general software control and data acquisition. As such, the term scada does not provide any useful information.
I assume that English is not your first language, and that some of the nuances of your problem are being lost in translation. Try posting in your own language. Although most people prefer questions in English, if it can be better understood in your own language, this is the better option.
If you get the impression I`m criticising your English, I`m sorry. This is not my intent. I just think you need
to post this question again with more information so that someone can help.
Shane.
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
(2,818 Views)
It would be helpful if you can provide a little more information on the type of application that you need and the system that it will be interacting with. For now, I would recommend taking a look at the products and articles on our website, www.ni.com, in order to learn a little bit more about the numerous products and solutions that are out there.
LabVIEW is a great way to get started, and with the release of v7.0, provides faster and easier-to-use programming. If you still need more information then I would recommend contacting your local sales representative or our support team of engineers.
Michael H
(2,818 Views)
