help me please
Hi
                I am a student doing my project, I am new in LabVIEW.As part of my project I need to interface a stepper motor for 3 axis movement, the 3 axis movements is controlled by a micro position controller, and i don’t know which micro controller is used in it, along with this I got  a software for 3 axis movement and its source code in Visual C++  and also they provided the assembly language of controller.I need to done this procedures from LabVIEW window how it is possible. I am using LabVIEW7.0
Thanks in advance
Dayaneeshya Thomas
Message 1 of 11
(5,880 Views)
Message 2 of 11
(5,873 Views)
 Sir
      Thank you for your reply, one more think  i need to know, I have a software and its source code( in Visual   c++),for       the 3xis movement. i want to know how it interface at  LabVIEW
    Thanks and regards
     Dayaneeshya Thomas
Message 3 of 11
(5,842 Views)
Do you want to call it in labVIEW or convert it to lv code?
Message 4 of 11
(5,834 Views)
I need to call it in labview,  the software codings are  6 different visual c++ program,  i have a visual studio 6. and working in LabVIEW7.0
Message 5 of 11
(5,814 Views)
LabVIEW can call DLLs. Thus, you could compile the C code into a DLL. My suspicion, however, is that the C code you have is probably written to be an application. This means you would need to take the relevant parts (i.e., the basic functions) and compile that into a DLL that you can call from LabVIEW. More information on calling DLLs from LabVIEW can be found in the LabVIEW Help, as well as Knowledge Base articles (just do a search on calling a DLL from LabVIEW). Examples also ship with LabVIEW.
Message 6 of 11
(5,801 Views)
sit ,
 thank you for your reply, i think this will be a great help for me.
    Dayaneeshya
Message 7 of 11
(5,767 Views)
Hi
You can use LabVIEW ".NET" connectivity for this purpose. After getting the source code, use the ".net" constructor node and property/invoke nodes to access the source code from LabVIEW.
I'm attaching an example program for your help (for LabVIEW 7.0)
thanks,
Ravi.
Message 8 of 11
(5,752 Views)
hi Ravi
please give  the example
   thanks
  dayaneeshya
Message 9 of 11
(5,743 Views)
It's here
http://zone.ni.com/devzone/cda/epd/p/id/861  🙂
Message 10 of 11
(5,737 Views)
