help me
hi all ,
i have a project where i must integrate a vision  camera into a robot .this robot have to take an counter and to make it in another side so in some cases somes counter may be arrive in a bad position so robot have to take it whatever its position. i think to use VBai to require position but i can't .can you help me to solve this  problem.
Any Help would be appreciated.
best regards
(4,622 Views)
@djokovic17 wrote:
hi all ,
best regards
If you are looking to hire a LabVIEW programmer to do this project, then I suggest you post in the LabVIEW Job Openings forum.
(4,594 Views)
i don't need to hire a labview programmer it is a project for me to do
(4,583 Views)
https://decibel.ni.com/content/docs/DOC-40451
Please read this post, then read your original question, then fix it!
Jim
(4,566 Views)
Help us help you.  What have you tried?  In what way is it not working?  And posting code helps too.
(4,562 Views)
It would be helpful if you provided images or sample code to help understand what you want to accomplish. Are you having trouble finding what you want in the image? Are you having trouble controlling the motors? Be more specific about the counter (i.e. provide images of what it looks like in the good position vs. the bad position).
Brad
(4,529 Views)
Brad
(4,529 Views)
