help me!
i use labview 7.1
one of the measurment set up is for measuring the transmitting voltage response of a transducer...
i have to measure o/p voltage first...
then arrange the set up for i/p voltage n measure i/p voltage without exiting the program..
for both voltage vs frequency plot is also reqd..
finally  calculate TVR...plot
i use menu cluster...n case strusture...
i have three cases...o/p volt
i/p wolt n calculate tvr...
i also have to save the tvr values n plot in a folder for future response..
i am new to labview..started using it a month back...dont know much abt file i/o operations..
i find difficult to tinel the values from case structure..
hope  u got me..
can u help me..?
thank u..
(3,746 Views)
(3,740 Views)
So you have a problem saving to a file. Why don't you say so in the post title??? 😉
Does everything else work? We don't really need all that detail if the only problem is saving to a file.
hope  u got me..
can u help me..?
Sorry, I didn't get it. What is "tinel"???
Maybe you should attach your VI so we can better guess what the problem is. 🙂
(3,737 Views)
i meant tunnel...
prob: tunnel values from case structure...to write to a folder
i cant send my vi...coz i use it on a diff pc..
thank u.
(3,732 Views)
fella:
As Dennis eluded to earlier, you should keep your problem to one single thread. That being said, I read both forum threads and I am still not sure about what your issue is. Are you having issues feeding values to the Write VIs in LabVIEW to do File I/O or is your issue with using tunnels in case structure or specifying a default file name to use?. Please be more clear and if possible, post the smallest of code you are having troubles with so that we can help better.
Rudi N.
(3,697 Views)
thanks to all who helped me..
my proble with the file write is solved...
thank u..
i have posted a diff thread...on a diff issue..
pls check n help.
(3,689 Views)
Fella:
Great to know that everything is working fine !
Rudi N.
(3,669 Views)
