help need in programmatically opened
hi, im new to labview.
hope you do no mind help me in this.
how do i programmatically opened a text if it's true?
like if the indicator show a letter A, how am i going to programmatically prompt something like a LED or button to show it's correct?hope you done mind give me an example. thanks
Message Edited by Divineapple on 04-13-2010 07:28 AM
Message 1 of 13
(5,013 Views)
Do you have code or an example for us to look at? That would be the easiest way to get help.
Tim
GHSP
Message 2 of 13
(5,006 Views)
using the help menu, open the find examples... then on the search tab, put in equals.  In the results you should see Equal- Various uses.vi.
You should be able to find what you need in there.
Paul
Message 3 of 13
(5,003 Views)
here is my client view, i need to show a indicator liek where is it and a led light to light up to show the location. but i only want it to promt instead of showing at the front panel i attach my server with the text file too
Message Edited by Divineapple on 04-13-2010 07:32 AM
Message 4 of 13
(5,000 Views)
oh btw i dont know the reson  why i must click search alot of times  b4 it could search
Message 5 of 13
(4,975 Views)
Hi DivineApple,
I'm not very sure what you are looking for, but it sounds like you want a message popup instead of front panel display?
If my guess is right, then you can make use of the Dialog functions from the Dialog & User Interface palette. This will allow you to pop up a text message.
If you want your own customized pop-up panel instead, then I would recommend that you use a subVI to decorate your desired display, then configure this subVI to pop-up when called and close after execution.
As for your current VI, looks like it should be working fine, though you can make use of a case structure to check for the different "A, B, C, D, E, F" characters instead of using multiple "Equal?" functions. This will make your code neater.
Boon Chen
Message 6 of 13
(4,944 Views)
how do i configure the subVI to pop-up when called and close after execution.
this is the subvi i had done but i not sure how to configure this subVI to pop-up when called and close after execution.
guide me if im doing wrong in my subvi.
Message Edited by Divineapple on 04-13-2010 11:00 PM
Message 7 of 13
(4,935 Views)
Insert you subvi to the main program. Right click to select subvi node setup,click show front panel showup & closed afterwards.
Message 8 of 13
(4,924 Views)
ok thanks but i do i make it auto close it after looking at it?
like after 30 sec the subvi front panel closes
Message 9 of 13
(4,921 Views)
you can put a delay inside subvi.
Message 10 of 13
(4,906 Views)
