help needed to convert 4.0 version llb to 6.0 or above
Can some help me convert the attached old llb (written in LV 4.0) to 6.0 or higher version so I can open it in LV 2012? Thx
(2,716 Views)
Accepted by topic author cencheng
Try posting here:  http://forums.ni.com/t5/Version-Conversion/bd-p/VersionConversion
Just for reference, here is a chart to help you know the minimum versions required.  Version 6.0+ is correct.
If someone helped you out, please select their post as the solution and/or give them Kudos!
(2,714 Views)
Post to the Version Conversion board. The link is at the top of the page.
(2,710 Views)
