help nieeded!
hi
I study (almos finish) on Silesian Technical University in Poland
I work on my M. A. thesis and I have a problem:
i have to create a virtual instrument fo LEM NORMA 6100 analyzer.
The problem is that I have to build construction like this:
___ configutration screen 1
Main screen ------- configutration screen 2
------ configutration screen 3
on every configutration screen i have to place button >BACK< (close conf
screen x and go to main screen)
I have to make it in LAbView 4.1 and I ran out of ideas.
(to be honest this is my first work in LabView)
In advance I used 'conventional' programming languages and i can't stop
think that
way.
I completly don't know how tu create 'a flow control' (for exaple: in pascal
or C i call a procedure and when it is finidshed the program goes back to
palce where the procedure was called from).
It's hard to show my problem in a few words. If anyone is ready to help me
I'll try to explain it and sent my poor tries in LabView.
I'll be grateful for any help
orzech
+ . pszczyna -> poland -> europe
(3,238 Views)
Orzech,
Make the pages you want to call into separate vi's (programs) and set the vi
properties of each to "Show Front Panel When Called" and " Close Afterwards, If
Originally Closed" ... then, use a Case statement and just put each vi into a
separate Case. When a Case is called, the vi front panel will open... when you
leave the vi, the front panel will close, thus showing your main selection page
(front panel) again.
good luck,
Bill
orzech wrote:
> hi
> think that way.
> orzech
(3,238 Views)
vi
Afterwards, If
into a
> separate Case.
OK, what should I do to close the vi (how to construct the 'close' button)
thx 4 help
orzech
+ . pszczyna
(3,238 Views)
Actually, you don't have to do anything... as soon as the vi completes the
page closes and exposes your main page again.
Normally if I'm in a sub-page, I stay there by using a while loop... the exit
button is tied to the loop control boolean (lower right corner of the while
loop).
When you leave the loop, the vi completes exectution and the front panel
"closes, since it was originally closed."
> vi
> Afterwards, If
> into a
> > separate Case.
> OK, what should I d
> thx 4 help
> orzech
> + . pszczyna
(3,238 Views)
