help on structure
Dear all,
I need big help. Please see the link and give me a sample structure how to initialize this in a dll. I can't able to understand it.
Mathan
Message 1 of 9
(5,753 Views)
Dear all,
How to implement this in LabVIEW?
struct {
    BYTE
        bCla,   // The instruction class
        bIns,   // The instruction code
        bP1,    // Parameter to the instruction
        bP2,    // Parameter to the instruction
        bP3;    // Size of I/O Transfer
} CmdBytes;
Mathan
Message 2 of 9
(5,737 Views)
Hi mathan,
you can create a cluster of 5 U8 elements.
Mike
Message 3 of 9
(5,735 Views)
how to initialize this?
Mathan
Message 4 of 9
(5,728 Views)
Hi Mathan,
After you create the cluster constant with U8, you would just have to type the initial value in. Check the second step of this link
Warm regards,
Karunya R
Message 5 of 9
(5,699 Views)
Hai,
Thanks for the response. I have created a cluster constant with 5 U8 values.
my problem is i have to pass this structure as an input(LPCBYTE) to pbsendbuffer parameter in that dll.
how to do this?
Mathan
Message 6 of 9
(5,672 Views)
Hi mathan, Smiley Happy
use as type "adapt types" or similar, it´s the the last but one element.
Mike
Message Edited by MikeS81 on 06-05-2008 02:22 PM
Message 7 of 9
(5,670 Views)
Dear mike,
Thanks for that reply. I will give it a try.
BTW,
BOOL QueryPerformanceCounter(
    LARGE_INTEGER *lpPerformanceCount );
Parameters:      lpPerformanceCount     [out] Pointer to a variable that receives the current performance-counter value, in counts.
Return Value:  If the function succeeds, the return value is nonzero.
How to initialize this in the dll(kernel32.dll)
Mathan
Message 8 of 9
(5,635 Views)
Hi Mathan,
I just need some information on what you are trying to achieve. Are you trying to call external code in LabVIEW? Or are you just trying to create an equivalent program in LabVIEW for your text based program?
Warm regards,
Karunya R
Message 9 of 9
(5,611 Views)
