help required in passing data to a database..!!
Hi all,
I am working with a VI which generates a table data as output and i want to pass this data to an online database, may be using SQL. But as I am not so good with SQL and other database management systems, can anyone please tell me how to do this. An example VI would be appreciated.
Thankful regards,
Nitz
Message 1 of 8
(4,588 Views)
Hi all,
It would have been very kind if someone cared to reply.
Nitz
Message 2 of 8
(4,573 Views)
You will want the Database Connectivity Toolkit. It comes with examples.
Message 3 of 8
(4,559 Views)
An alternative is to use LabSQL, but this doesn't have the support that the NI toolkit has.
Message 4 of 8
(4,553 Views)
I tried the database connectivity toolkit.. but i am getting an error..
Can you please tell me where am I going wrong.
Nitz
Message 5 of 8
(4,527 Views)
Here are few links you might want to have a look at
https://forums.ni.com/t5/Example-Code/Insert-Data-into-DataBase-from-an-Array-using-LabVIEW-Database...
Create tables and columns
Geeting column headers
Best of LuckSmiley Wink
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
Message 6 of 8
(4,517 Views)
Hi Gaurav,
Thanks for your help.. I will go through these examples and try to make out something..
Nitz
Message 7 of 8
(4,508 Views)
Hi ,
I tried doing this with the data connectivity tool kit.. But still I am getting some errors and not being able to get the results what I want. I have attached the vi and access file on which i am working. What i am trying to do is, when ever i press the enter button, i want the strings entered in the three string controls updated into the database table. But when I am doing this, the first value is getting entered and after that I am getting an error.
Please help me how to handle this data connectivity toolkit...
Thankful regards,
Nitz..
Message 8 of 8
(4,476 Views)
