help to build this VI please
hi guys
I am studying a Labview book and I am stuck in doing this example. I cannot wire the exit of while loop. In the attachment there is an JPEG file explains my problem. Please help me...
Egemen
(2,633 Views)
Accepted by topic author newbieeng
Your array on the front panel is undefined. All you have is an array container. You need to put an actual control or indicator inside the array to specify its datatype. Select a numeric indicator from the palette and drag it to the inside of the array container. That will define the datatype for the array and its icon on the block diagram will change.
(2,629 Views)
thank you very much 😄 It works.
Egemen
(2,625 Views)
