help to change string in number
I've a string " 1.001" and I want to change it in number but i take only 1.0. I had to do the median and I can't Please help
(3,211 Views)
try following format string to extract the number: %.;%f
Henrik
(3,211 Views)
Try this vi.
You must change the precision of your number indicator. you must set 3 for
the example you give.
Jerome LANGE
Strasbourg
andromed@club-internet.fr
"Razmocket-stagiaire" a ?crit dans le message news:
5065000000080000008F480000-1019262487000@exchange.ni.com...
[Attachment 1.vi, see below]
(3,211 Views)
The VI file that you attached is empty (0 bytes) ??
Lennie De Villiers
SYSTEMS DEVELOPER & SOFTWARE CONSULTANT
Tel: +27 82 4455949 Fax: +27 82 131 4455949
Email: ddevilliers@lando.co.za
(3,211 Views)
Hi Razmocket,
That's the same for me I can't open your VI.
So, which function do you use to convert from string to number ? Decimal string to number ?
MathieuT
NIF AE
(2,674 Views)
