help to understant code and "convert" it to the Labview
I am not at the office anymore, so I can't check that h-file I've used. BUT here is those files, You can easily see what was that correct h-file (if I member it right, it was USBscope50Drvr_if). And thank You very much for ur help 🙂
Message 11 of 13
(507 Views)
For that particular function the Import Wizard can't tell whether the float* means a pointer to a single float, or an array of floats. It's supposed to be the latter, but the Import Wizard doesn't have enough information to be able to conclude, so it picks the pointer to a single float. This means you have to change that particular VI. It's possible there may be others. Unfortunately, this is a limitation in C, and not really with the Import Wizard.
Message 12 of 13
(500 Views)
Ok. I try to chance it. Seems that h-file is created in 2005 and no updates available after that. And no eny support on manufacturers side Smiley Tongue
Message 13 of 13
(496 Views)
