help with Easy Print VI Panel
How are options such as which printer to use passed to this VI? The help file says to use the layout options input but what type of data is needed? I need to say which printer and paper orientation. Thank you.
(2,771 Views)
If you open the VI you will see that the "layout options" is a cluster. Place the VI on your block diagram. Place your cursor so that it is over that input (at the top). Right-click and select "Create -> Constant". Change the values as needed. You can also create a control if you want to feed this information from the outside.
(2,762 Views)
Exactly what I was looking for. Thanks.
(2,754 Views)
