help with HID communication
Hi can anyone help with this. Iam new to labview. I have recently purchased a transmitter for an oxygen sensor. This transmitter appears to connect to my PC as a HID device. Iam having difficulty gaining any information from the manufacturer up to now apart from that in the instruction manual it says that real time data is streamed via the USB. Can you give me any advice on how to initially connect to the device and read what ever data is being streamed ?
I have installed USBlyser which gives the following results fo the HID device i am trying to access. Any advice or help would be gratefully received.
(3,441 Views)
Accepted by topic author bwc1
duplicate post
No need to create a new thread. Stick to the original. Since you marked that one as solved and it obviously is not, click on 'Options' and change the status.
(3,439 Views)
Sorry coulnt find where to change the status to un solved
(3,435 Views)
