help with apparently simple prog!!
right ok. this is probably strighht forward to most, but i need help fixing my simple program. im having trouble with the wafeform generations. i get the felling its not always syncing correctly. how can i correct this so its constantly outputing 2 perfect pulse trains thaht are always in "sync" with each other so to speak, even when you change the phase of one pulse train. i also need it to count the number of pulses that have been generated since the start of an iteration.so far its ony counting as far as what i can see is the  number of pulses that occur  for the number of samples required for the sampling freq. i basically wnt it to count up indefinatley.
anybody?
(2,859 Views)
anyone?
(2,818 Views)
Hi Labnoob,
you should add a feedforwar/back node:
Make sure you initialize it with zero! (on the left hand of the while loop)
Ton
Message Edited by TonP on 12-04-2006 02:21 PM
My LabVIEW Ideas
(2,803 Views)
thanks mate. will my waveform ome out as a continous uniform wavform? its hard to tell as in the graph that is dispalyed comes out a bit funny
(2,781 Views)
