help with path and exe
Screenshot of MAX
Joe.
"NOTHING IS EVER EASY"
Message 11 of 15
(1,034 Views)
Possible Solution:
Uninstall DAQmx and re-install NI-DAQmx 8.0 from this location:   http://digital.ni.com/softlib.nsf/websearch/4C9E45F6EE5C29F98625708900712CBC?opendocument&node=132060_US
This may fix it if you were beta testing earlier versions of NI-DAQmx
Message 12 of 15
(993 Views)
I have never beta tested and this is were I downloaded it from to start with. I have a new PC and going to do a clean install of LV 8 and Daq 8 and see what happens when I try  to do the same build.
Joe.
Message 13 of 15
(980 Views)
Ok I just could not do a clean install on a new PC without getting it to work on this 1.
I used MSIBLAST and uninstalled all NI software
I then reinstalled LV8 and then reinstalled daqmx8.0.
After this I created a new project as I did before and created an installer and it build just fine.
thanks for all the help.
Joe.
Message 14 of 15
(959 Views)
Thanks for the update jhoskins -- I'm going to leave your service request with me open for a week or so, feel free to call in if you have any other build issues with it.
mike
Message 15 of 15
(955 Views)
