help with "a dynamic link library initialization routine failed" error message
I am using LabView 7.0 and I've been using it on the same machine for a while and when one day I tried launching my VI it gave me error message "a dynamic link library (DLL) initialization routine failed".
I tried different solutions that people tried but none worked for me.
Does anyone know why I would all of a sudden get this message?
I appreciate your help
Mario
(7,997 Views)
Hi Peter_Cherios,
Doest the error message give you further information about the DLL causing this ?
(7,995 Views)
@Mathieu Steiner wrote:
Hi Peter_Cherios,
This is what I get:
Error loading "D:Program Files\National instruments\LabView 7.0\vi.lib\Daq\lvdaq.dll"
A dynamic link library(DLL)initialization routine failed.
I've tried many things but nothing worked.
(7,971 Views)
Hi back Peter,
First of all, please check this link (even if according to your descrition, the install should have been done for a while). If this is not dealing with your problem, try the following -> give the user 'write' rights privileges to the directory "C:\Program Files\National Instruments\", in addition to "read", "list", and "execute" rights.
Have you tried to repair your softwares installation by going to the add/remove programs utilitie and click on repair ? This may solve the problem as well.
Hope this can help you in some way !
(7,964 Views)
