help with temperature control
hello again
I done some PID implement to the vi. some how, im not sure if it fits the description, any how can you take a look at it and see if im in the right track
thanks
Message 11 of 16
(1,740 Views)
nw,
It looks like you have implemented a simple PID algorithm although your code is not very readable.  I did not check the accuracy of your code, but it seems you are on the right track.  I am not sure what your DAQ questions are, but in general for single point DAQ you would open a reference to the DAQ task outside of your main loop, pass the reference into the loop and do a single point Read or Write, and close the reference at the end of your program.  There are many DAQmx shipping examples that show how to do simple DAQ tasks.
Doug M
For those unfamiliar with NBC's The Office, my icon is NOT a picture of me 🙂
Message 12 of 16
(1,723 Views)
thanks buddy,
I done the setup for the Daq, how ever; well i'm not clear how to make the hard wares run. see im using a deep fryer pot which is 115 vac, a water pump at 12 vdc and a electric fan at 115 vac. isn't there like a code that will run in sequental order from turning on the deep fryer pot , then run the water pump and last turn on the electric fan,,, im using a water coolant heating sensor from a chevy truck as a heating sensor, that sensor used 12vdc.       is there some sore of sensor for this job.
once again thank you, really
Message 13 of 16
(1,687 Views)
I'm not sure how to connect your hardware -- that is really up to you to know how to do, but as far as doing things in a sequential order I would suggest using a state machine architecture.
Doug M
Message 14 of 16
(1,670 Views)
Hi Guys
I tried to look at the PID demo but the version on the web is too  early. http://zone.ni.com/devzone/cda/epd/p/id/2382
How can I get a later version.
I'm running 8.6 Student eddition.
Regards
Message 15 of 16
(1,346 Views)
Hi noneqwerty,
You can use Example Finder, under Help»Find Examples... to locate examples on PID in LabVIEW 8.6.
Stephen Meserve
Message 16 of 16
(1,305 Views)
