help with vision assistant
Hey guys , i have a question in regards to using the vision assistant . i'm trying to make a program that recognizes objects so i followed this tutorial : https://www.youtube.com/watch?v=Ficfo5Zbip4
but when i try to run my detection in the photos that i put it in the training process it doesn't recognize them more than a few times no matter how many times i edit the object . also the problem is that when i try to fix the rotation for example of the detection box it messes up all the other cases that worked.
Message 1 of 1
(1,343 Views)
