Showing results forĀ
Search instead forĀ
Did you mean:Ā
help
hello
i understood that i can use ohmĀ“s law ....and also i have 10 ohm resister which is attach to my laser diode driver ...but my question is how to volatge vs current graph ...with step of 0,1 V....using usb6009  here you can see my graph which i am trying to get.....
Message 11 of 52
(2,432 Views)
hello
thanks
Message 12 of 52
(2,426 Views)
Hi raoof,
These steps are required:
1 output a voltage
2 read the corresponding voltage across your resistor and calculate the current
3 back to step 1 for all voltage steps
4 display all current vs voltage values in a XY graph
Message 13 of 52
(2,426 Views)
hello
i got 001.5 mv as ouput...?is that right??
how i can get corresponding  volatge valuses  across resistor  sir????
so plot currnet vs voltage
thanks
Message 14 of 52
(2,421 Views)
You have to vary some voltage source as an input.  You measure the current by measuring the voltage drop across the resistor.  So for each set voltage, you have a current.  Build those numbers into two arrays (one for voltage and one for current) and use an XY graph to create your plots.
1.5mV across a 10 Ohm resistor would be 150uA.  How much current are you expecting?
Message 15 of 52
(2,406 Views)
hello sir
how i can vary volatge ....?because i given 5V FROM POWER SUPPLY ,,how can i vary it..and where i should  read volatge drop ...as i am not able to see my multi meter please send me 2 array program sir.
thanks
Message 16 of 52
(2,403 Views)
How do you expect to do an IV curve when you can't set the voltage?  How do you tell the driver what voltage to put out?
Message 17 of 52
(2,392 Views)
I really think you have to back to square one and define your requirements before attempting anything else.  From what I've read, you don't really know what you want to do, how to do it, or with what instrumentation.
Bill
CLD
(Mid-Level minion.)
Message 18 of 52
(2,389 Views)
hello
sir i am cofused ...i have 5 v ..but i am not able to vary please tell me how i can vary this 5 v which is constant ......
and can i get  your skype id ..which will be more more easy to tell you and get my solution please help me out...as i am new to labview this is my frist time using labview ......hope for the best
thanks
Message 19 of 52
(2,380 Views)
billko is right here:  the help you actually need right now has nothing to do with LabVIEW.  Your problem is you don't even know what you are trying to test.
So from I have been able to gather here, the goal is to perform an IV curve.  What device is this curve supposed to be done on?  If you are doing an IV curve, you need a supply that you can vary, preferably via serial port or USB (so that we can control it in software).  The measure current, you will have a 10 Ohm resistor in series that you can measure the voltage drop and derive the current.
So let's try to get that setup before we start doing anything with code.
Message 20 of 52
(2,373 Views)
