help
Hi Toni,
no problem. Now there is the query vi and a global missing. Smiley Happy
Mike
Message 11 of 17
(1,113 Views)
Hi Mike
I didn't understand what do you mean there is the query vi and a global missing . can you please give more details. what should i do ?
Toni
Message 12 of 17
(1,107 Views)
Hi Toni,
i only mean that there are the following vi´s are missing. "C844_query.vi" and "C844_PortGlobe.vi". That´s all. Maybe you can upload them.
Do you know where the error from yeterday occurs??
Mike
Message 13 of 17
(1,105 Views)
Hi Mike
I am still working on it . I have to clear the memory. I am trying to write *STB? in query.vi to clear the register after that i stoped the axis maybe it works, but everytime i stoped the axis ,  i have to shut down all the vis and to restart  them once again.
I noticed something that if I stoped the axis and restart the code again , the axis moves the rest of the first step + the new number of new step.
TOni
Message 14 of 17
(1,101 Views)
Hi Toni,
there is still one vi missing (C844_receive). Did you find the VI where the error occured?
Mike
Message 15 of 17
(1,073 Views)
Hi Mike
yes I found the error . thank you a lot man .
I have another question .
1) to stop the axes I have to click with the mouse on the STOP buttom. is there any possibility to active this buttom using ALL the Keys on the keyboard and not just only one key (e.g. ESC)
2)The STOP command works like an emergency stop-switdch and I require to close the VI after the buttom is clicked.
any idea? ( I read about Quit labView)
Toni
Message 16 of 17
(1,068 Views)
Hi Toni,
to use more than one key you can use a sequence structure. There you can handle all key down events. To close the vi after stop it, you can use the reference of the vi and set the property FP.open = false, after that close the reference.
Mike
Message 17 of 17
(1,059 Views)
