helppppp
Exception: Access violation (0xC0000005) at EIP=0x01137080
Message 1 of 13
(4,305 Views)
0xC0000005
How on earth do you expect any help without giving any details whatsoever?
_____________________________
- Cheers, Ed
Message 2 of 13
(4,294 Views)
Don't do that!
Seriously, Could you find some meaningful way to restate your request?  Do you have a problem with code that reports that error?  Do you want code that causes it? Your post is meaningless to us.
Message 3 of 13
(4,288 Views)
My appologize for the short information, am new in this forum.
this morning i tried to run my 13.0 f2 labview (32-bit) and the system show the following crash report
Version: 13.0f2 (32-bit)
Message 4 of 13
(4,281 Views)
Message 5 of 13
(4,268 Views)
Is your application running in the development environment or runtime? Are you able to isolate the issue to a particular VI?
Or do you mean you tried to open LabVIEW and it is LabVIEW itself that has crashed?
- Cheers, Ed
Message 6 of 13
(4,242 Views)
Am running in development enviroment just when i try to open labview
Message 7 of 13
(4,231 Views)
Are you opening LabVIEW by opening a project, and letting LabVIEW load up
or Start -> LabVIEW
This will help determine whether it's a problem with the project, or your LabVIEW installation
- Cheers, Ed
Message 8 of 13
(4,227 Views)
no the same report appear in my computer.
Message 9 of 13
(4,216 Views)
A likely cause is that someone moved or copied a dll that LabVIEW depends on.  use the control panel add/remove programs to attempt a repair of LabVIEW.
Message 10 of 13
(4,205 Views)
