hermitian of 1-D array
Hi every one .
I should multiply  hermitian of array A (for example) to A. for hermitian of one dimention array , I can use conjugate and transverse but unfortunately transverse is for 2 -D array. I read some posts befor that transverse of 1 dimentional array doesnot have meaning but when I want to multiply hermitain array A to A , it has some meaning.
Thank you for your help
Message 1 of 14
(4,342 Views)
Also if anyone knows the output of Zherk??? I confuse what is C in that VI? I thought the output is Hermitian A or...
Thank you
Message 2 of 14
(4,340 Views)
How do you define a Hermitian on a one-dimensional array?  Every definitiion I have seen requires a 2-D array.
The description of zherk in the detailed help file seems to be quite explicit. What do you not understand?
Edit: A quick test shows that it will run with A being a 2-D matrix with 1 row and C beinb a 2D matrix with 1 row and 1 column.
Lynn
Message 3 of 14
(4,326 Views)
I do not understand that what is the output of zherk.
I want to multiply hermitian of A to A. how should I do that?
hermitian meand transpose and conjugate but transpose input is just for 2 D array.
Thank you
Message 4 of 14
(4,282 Views)
Accepted by topic author uni-pixel
All you need to do is to change your 1D array into a 2D array, then transpose it.
Bob Schor
Message 5 of 14
(4,264 Views)
your answr is something else.
I want to multiply hermitian of 1D array to 1D array.
some one please help.
BR
Message 6 of 14
(4,255 Views)
you mean buid array change 1D array to 2 dimention array ? what is the content of the secon dimetion?
Message 7 of 14
(4,246 Views)
If you run my program, you'll see that "Row Array" is a 1-row, 5-column array having the numbers 0 .. 4, while "Column Array" is a 5-row, 1-column array having the numbers 0 .. 4.  Think of them as "Row Vector" and "Column Vector".
These are both 2D arrays.  How are you doing array multiplication?  I assume you realize that, in LabVIEW, an Array is not a Matrix.
BS
Message 8 of 14
(4,233 Views)
thereis another proble.
when i multiply hermetian A and A , with A*B VI, There is no output.
so there is a problem and errod.
Message 9 of 14
(4,221 Views)
if you multply array colum to  one another array, it will be error.
what should i do at this point.
Message 10 of 14
(4,210 Views)
