hex convert to decimal
  • Hi, Im trying to read DYN-200 torque sensor. My value from the read buffer is quite weird it show 2D30 2E30 302D 302E
Message 1 of 13
(3,040 Views)
How are you communicating with this sensor? Which Modbus library are you using? You might want to share the code so that we can understand better.
https://tmesystems.net/
Message 2 of 13
(3,031 Views)
Hi, i dont have the code..
but this sensor got three kind of communication mode.Im currently doing the mode 0 which will provide torque and speed value.
mode 2 only provide torque value
i will send the picture.
Message 3 of 13
(3,013 Views)
I am new to labview. For mode 0 need to use modbus library?
Message 4 of 13
(3,012 Views)
Based on the screenshots of the user manual you shared, Mode 0 of HEXactive upload protocol is meant for the upper machine designed by the company.
Since you mentioned that you don't have any code, I guess you are using the NI-VISA Interactive Panel right now. NI-VISA sends and reads the data in the ASCII format, thus you should use the Mode 2 of ASCII Active Upload Protocol instead. In page 6 of the manual, it states that:
A piece of its data format such as: 2B 30 2E 30 30 30 31 0D
This aligns with what you are seeing currently.
Message 5 of 13
(2,952 Views)
So you get a raw string of six bytes, which consists of three 16bit values. The first is toque (U16), the second is speed (I16) and the third is a checksum. Once you can read these size bytes into LabVIEW, the rest is trivial.
Message 6 of 13
(2,942 Views)
So for mode 0, im not able to use NI-VISA to read the value?
For mode 2, it only sends torque value. I test it out and is able to receive the torque value.
Message 7 of 13
(2,913 Views)
I uses VISA-Ni to read but get random value
Message 8 of 13
(2,912 Views)
You need to be significantly more specific.
Message 9 of 13
(2,837 Views)
thanks for replying me, I planned to use modbus
Message 10 of 13
(2,807 Views)
