hex display to number
Hi :
I have txt string which appears as hex display , I want to convert it to decimal number
Attach see file please , I always get 0 at numeric
What I need I have number 00000457 ( hex) I want to convert it to decimal number it should be 1111
But my problem is the txt string is already in hex display
can any one help with this issue
thanks
Message 1 of 16
(4,515 Views)
Try writing only 457.
Message 2 of 16
(4,510 Views)
I can't this number i get for another application
Message 3 of 16
(4,508 Views)
Like that?
Message 4 of 16
(4,500 Views)
try this subVI
I hope it will work with other inputs.
Message 5 of 16
(4,496 Views)
how about this?
Message 6 of 16
(4,487 Views)
I can't open the file i have labview 2009
when i try open it this message that i file saved with labview version 2010 , can you please saved it with labview 2009
thanks
wisam
Message 7 of 16
(4,473 Views)
that should work.
Message 8 of 16
(4,468 Views)
An string of char (equivalent to an array of bytes) representing an I32, U32 (or any other data) can by directly type cast to the type it represents.
See the attached VI.
Message 9 of 16
(4,461 Views)
Accepted by topic author Elyan_wisam
also possible are the other two methods shown in the attached example.
Mike
Message 10 of 16
(4,461 Views)
