hex string to decimal number
As attached. If input a positive number, all right. If input negative number, the result is strange.
(3,421 Views)
Look at this picture. You are comparing a I32 (signed) with a U32 (unsigned). Same number big difference:manhappy:
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(3,418 Views)
Hi Opt_Ottawa,
you really should be careful about datatypes! Your "input" is different to "output" regarding the datatype. You should also spot this red dot at one input of the equal operator - this is Labview's way of telling you to check datatypes!
The"hex string to number" has a default input where you can set the required datatype too - RTFMor atleast the context help carefully!
(3,410 Views)
got it. Thanks for help.
Opt
(3,389 Views)
