hexadecimal string to 14 bit unsgned integer
I have a hexadecimal value which contains 14bits two complement. How can I convert this to an integer value?
Your help is greatly appreciated.
Chathuri
(3,235 Views)
Hi Chathuri,
how do you have the value? In which format, in which type of control? Can you give more information. Maybe you can give the hexadecimal value and the expected result.
Mike
(3,231 Views)
hi Mike,
i have a string control which I have typed the value let's say 3E6B. The format for the string control has been set to hexa decimal. The 3E6B is a 14bit value which is two complement. So when I convert it to an integer the value I should get is -405 in decimal.
Let me know if you need anymore clarifications.
Thanks!
(3,227 Views)
This should fix your problem 😉
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(3,219 Views)
thanks.. it was simply awesome. Im new to Labview and it helped alot. Thanks !!
(3,186 Views)
