hexadecimal to decimal
How can I convert from hexadecimal to decimal and vice versa?
ToNi.
(2,846 Views)
Yes you can.  Are you wanting to convert a hex string to a numeric?  If so use the Hexidecimal String to Number function found in String - String/Number Conversion.  If converting hex number to a decimal string, use the Number to Hexidecimal String function.  If you just want to display a hex version of a decimal numeric (non-string), right click on the numeric indicator and click Format & Precision and choose hex.
- tbob
Inventor of the WORM Global
(2,829 Views)
One thing to add:
Displaying a numerical value in hexformat is only selectable when your representation is a [I,U][32,18,8]
This is not due to a priciple. Every number can be displayed in any base, but is doesn't seemed to be a problem in the pastSmiley Wink
Greetings from Germany
Henrik
LV since v3.1
(2,814 Views)
