hi, I want to make a diagram of a transmitter receiver in labview, but I did not find the suitable pallets, need help
To achieve the issuer:
· Type a text
· Transform being bit
· To associate each bit a voltage,
· Give shape to the pulse associated
· The modulate,
· Send the result to the sound card.
(2,556 Views)
Hi angel,
you have been given a task and you have been given a picture of the block diagram. Now you need to recreate that BD?
As it uses some custom made subVIs, you will not find them in the (standard) function palettes!
It seems that's the part of the homework you have to do on your own 😄
(2,533 Views)
