hi
hi,
I AM WORKING ON STATUS BAR,
BUT I AM FINDING IT VERY DIFFICULT TO POSITION IT, SO PLS IF ANYONE KNOWS HOW TO PLS HELP ME
REGARDS
narayan
(3,339 Views)
hello,
its fine if you are working with status bar, but i didn't understand what kind of position you are trying.
Please if possible, ellaborate your question a little bit more.
Thanks & Regards,
Samriddh Sarbalhi
(3,327 Views)
hi,
i have 3 case statements running one after the other where after each case statements got completed the status bar should fil about 30 % and all my 3 cases are running in a sequence and after each proved true it will have a bollean indication on front panel same way i want status bar to be updated after each case got completed by the end of sequence when all cases are over status bar shold be full.
regards
NARAYAN
(3,313 Views)
Have a look at the attached example.
R
(3,295 Views)
