hide and make visible a group of buttons controls or indicators
HI
well, may be sound weird?, but I need to hide and make visible a group of buttons, controls, indicator, graphs etc.
the pint is that I have for example like 20 buttons, and depending of the actions of the users I need to hide them or not, I know I can do it one by one with the visible property, but I was wondering if there is a possibility to do it but all together, with the same property, like put all the buttons or control inside a subpanel and then hide the subpanel? I tried this but didn´t work
any suggestions?
thanks!!!!
(5,380 Views)
Hi Sirrick,
if you use a subpanel you can unload the loaded vi from the subpanel. The vi runs anymore in the background but you don´t see it.
Can you show us some code?
Mike
(5,373 Views)
Hi again,
i make an example for you to show how it can work. An other way to hide many controls or indicators is to get all references from the frontpanel with a property node and run through a for loop.
Mike
(5,362 Views)
You can put all of your controls in a cluster. The reference to the cluster - Property node> Controls [] - will be an array of references. From there you can control the visibility of each control.
PaulG.
Retired
(5,359 Views)
1. logical groupings of can be clustered
2.  Tabs can also group controls simplier than subpanels
3.  State machines eish a show hide state allow all show and hide logic can be in one place.
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(5,335 Views)
thank you very much to everyone, was really usefull.
PaulG.  sorry but I have LV 8.0 then I coudn´t open your example, but thanks any way
(5,323 Views)
Here you go in 8.0:
PaulG.
Retired
(5,303 Views)
