hide / disable main vi when subvi is called
Hi all
I have main vi and sub vi... How can I disable / hide the main vi from user clicking it when the sub vi is called? Thanks!!!
Message 1 of 12
(4,847 Views)
Use vi reference, vi properties, pront panel window property, state, there are minimized or hidden.
________________________________________________________
Try to make everything Automatic
Message 2 of 12
(4,839 Views)
Yukee, thank you so much....
Message 3 of 12
(4,836 Views)
But anyway, it doesn't have a control to disable the front panel of main vi.. So the user is able to click on main vi even when the sub vi is running.. How to solve this problem? Thanks
Message 4 of 12
(4,831 Views)
use control item's property, there are a disable function, "0" is enable, "1" and "2" are disable.
Message 5 of 12
(4,831 Views)
where can I find the control item property? Show me the way plsssss...
Message 6 of 12
(4,825 Views)
See Enclosed, there are a simple sample for you to enable or disable the control item.
Message 7 of 12
(4,825 Views)
HI yukee
This will only disable the control / indicator... But want I wanted is to disable the window of main vi when the subvi loads.. In other words, user will not be able to click on the main window (or front panel) until the sub window close.. How can I do that?
Thanks!!
Message 8 of 12
(4,819 Views)
Hi 222,
            Smiley Happy as I told you how to disable or enable the control or indicator's item.
As you demand that you can disable all of control where are in the main window as the subVI called, after close the subVI, enable all that controls ? is it not your demand ?
maybe you can use hidden main Vi window to realize ? and you can "invalid" the main vi window.
Message 9 of 12
(4,818 Views)
222 - you could make your sub vi modal (settable in the vi properties). So just the subvi will have focus and no other vis.
Using LV8.0
Don't be afraid to rate a good answer... 😉
Message 10 of 12
(4,815 Views)
