hide subVIs by making them .dll
I know I read somewhere about how to do this but i cannot seem to find the posting.  Anyways, i have a project that i want to deploy and it contains several classes which use inheritance.  So the application builder creates several subdirectories with all the overridden methods of the classes to avoid name collisions.  I was hoping there might be a way to mask these *.vi files into *.dll files.  If anyone knows of a way to do this that would be great.  I just don't want someone opening these VIs and changing them.
Brent
(3,382 Views)
In the build executable dialog;
First in the source files sections add the Classes to the always included list
Second go to the Destinations section. Change the Class' destination from Directory to LLB. This will create a file as opposed to the directory.
Lastly, amend the the destination path from *.llb to *.dll
_____________________________
- Cheers, Ed
(3,368 Views)
ok i was able to add the classes to the always include list, but when i goto the destination section i have two choices under destinations (CC.exe and Support Directory).  CC.exe has the Destination type grayed out, im assuming that is correct because it is the exe and contains most of the VIs.  Support Directory has Directory selected but all those options are grayed out as well so i cant change it to LLB.  Any reason why it's acting differently than yours?  Im using LabVIEW 8.6 btw.
(3,352 Views)
Accepted by topic author BrentSchenk
My apologies. I was going on memory rather than working through it.
In the destination section you need to add a new destination and change the label and path - for instance .\CC\data\NewDestination.dll
Next, in the source file section highlight the class and change it's destination to the newly added one in the drop down menu. You can leave the Rename checkbox unchecked at the bottom.
- Cheers, Ed
(3,329 Views)
thanks for the solution! 🙂
(3,309 Views)
