hiding the taskbar and monitor resolution
I have an application where I am dynamically changing the monitor resolution
to
800x600(if its not already set). However, I end up losing the taskbar if
I am
changing from a higher resolution. I guess the taskbar position doesn't
change with the resolution change. does anyone know how to change the
position of the taskbar dynamically. Also, does anyone know how to switch
the taskbar setting to auto-hide programmatically. thanks.
pat
Message 1 of 1
(2,711 Views)
