high resolution graph
Hello everyone,
I am creating a program in which data (X, Y coordinates) from a file will be showed in XY graph in labview. The problem is that i have 1000 pairs of X, Y coordinates, but the graph did not display well as attached image.
Now i want to create a smooth curve, is it possible? I think the problem is the configuration of the graph, is that correct? Could you give me any idea?
Thank you 🙂
(4,707 Views)
p/s: added the sample files...
(4,690 Views)
Accepted by topic author eric.miller
Hi eric,
use a proper format string like "%f" for those ReadSpreadsheetFile functions and your VI looks quite nice:
(4,642 Views)
Hi GerdW,
I did it. Thank you very much Smiley Happy
(4,613 Views)
(4,550 Views)
