high sampling waveform chart display trouble
I have a vi that is datalogging at 10Khz. I am trying to continuously display the data on a waveform chart.  At this rate, the chart can only display a couple seconds worth of data and  then automatically clears.  I have attempted to set the chart history length to the max but it had no effect. I'm using a cDAQ setup and have the waveform chart in a while loop.
I am saving all the data so it's just the chart that isn't working how I'd like.
Any suggestions?
Cheers,
-Jesse Denson
Covidien
(2,650 Views)
I think you can use a waveform graph instead the waveform chart.
(2,644 Views)
JDfromRI <x@no.email> wrote in news:1216653010475-747911@exchange.ni.com:
> Any suggestions?
Yes. A continuous display at 10KHz is not very useful, and impossible for
a human to interface with in a meaningful way.
Figure out what the REAL requirements are. Chances are that you really
want some sort of decimation to be displayed.
Scott
Reverse name to reply
(2,642 Views)
