high scale-density plot
I think the comma and dot notation are set by the OS. LV has an option to Use Localized Decimal Point.  Look at the help and try the different settings to see if this does what you want.
Lynn
Message 11 of 12
(540 Views)
Problem solved.
The reigistry value HKCU\Control Panel\International\sDecimal has to be read in order to see whether the system uses the comma or the dot.
22713i2EEA755241A05DB6
Message 12 of 12
(534 Views)
