high speed buffer DAQ
Hi
I' m using a CRIO 9012 along with NI9215 for high speed data acquisition. I used the example given by NI ( http://www.ni.com/white-paper/3268/en/ ). However, I got strange results. Could you help me to find out the problem ? In the attached pic I used low voltage source but even at higher voltages , the same happens.
(4,313 Views)
Hi UserLab,
Thanks for getting in contact with us. Before I can give a solution I was hoping you could provide me with some further information. Could you let me know what chassis you are using with the cRIO 9012 and NI 9215 module. Also the 9215 is a 4 channel analog input module, could you please describe what you have connected to the module and the expected behaviour.
Hopefully together we can resolve this issue.
Best Regards,
Soloman
Application Engineer (CLAD)
(4,235 Views)
Hello
I am using a CRIO9102 chassis. The problem is when I run the VI I measure with much descrepancy from the expected value. Fon instance in the attached pic below I measure 5V DC. I am not sure about the aquisition speed performance of this crio.
(4,217 Views)
Hi
I would like to know if the high speed buferred aquisition can be done by a 9012 controller and 9102 chassis. Any help ?
(4,152 Views)
Your problem is how you are transferring the data from the FPGA to the RT.  You should be using a DMA FIFO to send the data directly to the RT.  This will make things A LOT more efficient and you won't be losing data.
(4,128 Views)
