highlighting different plots
I have an application where I generate10-20 different plots on one graph.  I know how to use the legend, but it's still tough to see which plot goes with which data set.  Is there a way have the individual plot names show up when I mouse over a plot?  It would be like the excel plots.  When you put your mouse over top of the plot, it tells you which data set your looking at.
(2,607 Views)
You can find code which will tell you which plot you're closest to here.
You can modify that to get the plot name even without clicking and to display it.
___________________
Try to take over the world!
(2,598 Views)
Wow, that is more complicated than I thought it would be.  Thanks for input.  I'll definately give it a shot.
(2,583 Views)
