histogram problem
Hi all,
I have a bit of an issue with the VI I am running and was wondering if anyone could help. I am running a test to calculate the heat transfer coefficient.
At present the VI runs over a set amount of time however I have a couple of requests:
1) when finding the mean Heat transfer values I want to find the mean of the last 1000 points and then write it to the measurment file (hopefully a table format)?
2) once this is done, I hope for the data to be then read off the file and displayed in a histogram (as shown). The only problem is that when I do this I want to be able to distiguish the most recent point recorded and i have no idea how to do that!
Thank you all.
Neil
(2,981 Views)
hi,
for the mean my solution.check the JPG
for histogram the solution is to create a general histogram with all value. and another with same scale but whit just the last 1000 points
(2,883 Views)
