histogram property nodes
Hi
im using general histogram   vi in signal processing toolkit to get the axis and histogram and im feeding the axis and histogram to the vertical bar gram with limits.The vertical bar graphplots totally seven plots in a graph.the seven plots are (process mean...upper and lower limits ,Histogram....)what i need is when the histogram value ie the acquired value exceeds the limits i want to change the colour of the histogram
only  not the upper limit or others....ie.how to change the the property of a single plot?
 with regards kavi
kavi
Message 1 of 1
(3,026 Views)
